I have the same problem as the other poster and i didn't see a response.
Here are the simptoms:
-Rolling at idle speed or just above there is a rubbing noise that seems to be coming from the left rear tire. Once I noticed it I replaced all rotors and pads, front and rear. It needed it anyways. Noise stayed
-Noise seems to stop if I touch the brakes.
-Noise has gotten progressively loader
-I replaced all tires and had an alignment, noise stayed
-Rear CV joint seems to be intact and in good running order by appearance.(no cracked boots, not broken seals. Feels firm)
-Tested rear caliper by taking it off the rotor and pressing the brake, It seemed to compress normally.
-I am also hearing a lot of squilling from the rear brakes, they are still very new. I cant seem to get rid of it.
I have done the same basic things and no change. Please let e know. Thanks Zach
Feb 29, 2008 at 11:43 PM
