HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Santa Fe
Engine
Camshaft
Camshaft Sensor
2002 Hyundai Santa Fe CAM sensor
TIMBO24
MEMBER
2002 HYUNDAI SANTA FE
Electrical problem
2002 Hyundai Santa Fe 6 cyl Four Wheel Drive Automatic
what is the most common thing to go wrong with the cam sensor? The wiring or the sensor itself?
Wednesday, August 18th, 2010 AT 6:28 PM
BLUELIGHTNIN6
MECHANIC
The sensor itself
Wednesday, August 18th, 2010 AT 6:29 PM
TIMBO24
MEMBER
Yes you did help me. Thanks
Thursday, August 19th, 2010 AT 4:41 PM
Please
login
or
register
to post a reply.
Related Camshaft Camshaft Sensor Content
Starts And Runs For 3 Seconds
Is There A Sensor That The Computer Wants Information From After The Engine Has Been Running For 3 Seconds?
Asked by
itsallgood
2002
HYUNDAI SANTA FE
VIDEO
Camshaft Angle Sensor Replacement P0015
Instructional repair video
GUIDE
Camshaft Position Sensor Symptoms
An automotive engine camshaft position sensor is a simple two wire magnetic sensor that triggers a signal to the engine control module. This information is then used to help...
Dieseling Efi Engine
My Vehicle Does Not Switch Off Straight Away And I Have To Stall The Engine To Turn It Off. After I Turn The Key To Off The Engine Does A...
Asked by
tsg333
2 IMAGES
2002
HYUNDAI SANTA FE
2002 Hyundai Santa Fe Camshaft Location
Hello There I Just Wanted To Know If You Guys Could Tell Me Where The Camshaft Are Located At On A 2002 Santa Fe. I Had Trouble Finding It.
Asked by
JeanPaulGC
1 IMAGE
2002
HYUNDAI SANTA FE
2002 Hyundai Santa Fe Starting After Fueling
History-july 02,2010 I Had A Trans Axle Baring Repaired And Something Else I Can't Remember, I'm Not Near The Paper Work At This Time, But...
Asked by
hi5Santafe
2002
HYUNDAI SANTA FE
Engine Problems 02 Sante Fe
I Have A 2002 Hyundai Sante Fe And The Timing Belt Broke And Bent The Valves We Have Replaced The Valves And Timing Belt New Gaskets And All...
Asked by
mr.ginohoward
2002
HYUNDAI SANTA FE
VIEW MORE
Is it Safe to Drive Check Engine Light?
Code Read Retrieval/Clear - Dodge Stratus
