whistling noises
HYUNDAI
BDZ78
I have a 99 hyundai accent, 130,000 miles, 4 cylinder engine. My question is what would cause my car to make a whistling noise,, when i fisrt start it up. I turn the engine on, and i hear a whistling sound coming from the front, but it stops after about a minute.
May 22, 2007 at 10:31 PM
TURBOTUFF20G
  • 98 POSTS
whistling noise is usually some sort of intake or vaccuum leak, have some 1 listen under hood when u start it up to try to pinpoint area where the noise is coming from. I have seen intake gaskets do this B4
May 27, 2007 at 12:01 PM
TURBOTUFF20G
  • 98 POSTS
Is this car a standard???? if so i have also seen lack of lube on pivot clutch bearing do this also,, see if noise goes away when u push clutch in if its a 5spd
May 28, 2007 at 8:10 AM
