2000 Hyundai Sonata Belt Squeal
HYUNDAI
SONATA
Hey just wanted to know how to get rid of some annoying squeling noises comming from the fan/drive belts. I've already tightened the tension of the belt it has made it better but its still there!! What can I do to fix the problem. I drive a hyundai sonata 2000. also the battery wire which drives my stereo is not working. How can I fix this, I checked the fuses but I can't find the problem!! The car has done 150000km. Thanks
Feb 26, 2006 at 12:46 PM
PEPPERMRJ
  • 1,158 POSTS
[quote:a43393fc27="Sonata"]Hey just wanted to know how to get rid of some annoying squeling noises comming from the fan/drive belts. I've already tightened the tension of the belt it has made it better but its still there!! What can I do to fix the problem. I drive a hyundai sonata 2000. also the battery wire which drives my stereo is not working. How can I fix this, I checked the fuses but I can't find the problem!! The car has done 150000km. Thanks[/quote:a43393fc27]
Either replace the belt or pull it off and check all pulleys by spinning them by hand.
Run a new power wire. :)
Good luck and let us know. :?:
Mar 3, 2006 at 9:52 AM
Suggested Repair
Replace the drive belt, or remove it and spin each pulley by hand to check for binding. For the stereo, run a new power wire from the battery.
Conversation Summary
The owner of a 2000 Hyundai Sonata with 150,000 km reports fan/drive belt squealing that improved after tightening but did not stop, plus a battery wire feeding the stereo that still does not work after the fuses were checked. The expert advises replacing the belt or removing it to hand-check all pulleys, and running a new power wire for the stereo.
