2002 Hyundai Accent Check Engine Light
HYUNDAI
JKNMODELS
2002 Hyundai Accent, 120,000 miles
The engine check light goes on then off. (Stays on for for about 50 miles then off for about the same)When the light is on, it is almost impossible to fill the tank with gas. When the light goes off the tank can be filled without any problems. Any ideas?
Dec 13, 2006 at 2:02 PM
MEM-TEK
  • 7 POSTS
[quote:0f5c5c8d6c="jknmodels"]2002 Hyundai Accent, 120,000 miles
The engine check light goes on then off. (Stays on for for about 50 miles then off for about the same)When the light is on, it is almost impossible to fill the tank with gas. When the light goes off the tank can be filled without any problems. Any ideas?[/quote:0f5c5c8d6c]
Wow! This really doesn't make much sense, does it? After all, a fuel tank is just a tank. The only think I can think of is something which a mechanic told my mother regarding her Toyota many years ago. The mechanic suggested that my mother never let her tank go much below half full as the tank's internal baffles could collapse. Apparently fuel tanks have baffles to prevent the gas from sloshing around.
I guess the symptoms you are seeing could suggest that the tank's internal baffles have collapsed. This then could cause problems for the fuel pump (inside the tank) when trying to draw fuel from the tank. That in turn could be causing the check engine light to come on intermittently.
This is all just a guess; hopefully somebody else with more experience will chime in with a better answer. :?
Dec 30, 2006 at 10:22 AM
SERVICE WRITER
  • 9,123 POSTS
You need to find the code in the computer for starters. Probably a "PO440" as a guess. The evap system uses vacuum or pressure to run the self tests or monitors. It tests for leaks , soleniod operation, valve operations.
Dec 30, 2006 at 2:48 PM
Suggested Repair
Scan the computer for stored codes first. The expert suspects an EVAP-related code such as P0440 and recommends checking the EVAP system for leaks and for proper solenoid and valve operation.
Conversation Summary
The owner of a 2002 Hyundai Accent with 120,000 miles reports a check engine light that stays on for about 50 miles, then off for about the same distance. While the light is on, the fuel tank is nearly impossible to fill; filling is normal when the light is off. A user guessed that collapsed tank baffles might affect the in-tank fuel pump. The expert advised retrieving the stored code first, guessing P0440, and noted that the EVAP system uses vacuum or pressure to test for leaks and solenoid and valve operation.
