2006 Other Hyundai Models check engine light
2006 HYUNDAI
18,756 MILES • 6 CYL • FWD • AUTOMATIC
USFARBUO
My azera was bought new and within the last 5 months the check engine light has come on and each time I called the dealer to make an appt. (within 2 days) the light has gone out before the dealer could check it out. I t came on again last night and this morning it went out by itself again. Do you have any idea what could be causing this.
Except for one time when the car ran rough (and then ran well after I shut it off and restarted even though the light was still on) it has been running fine.It's a problem running to the dealer every time the check light engine goes on. Other than that, I love the car-it's a gem
Thank You
Mar 3, 2008 at 3:27 AM
  • 31,937 POSTS
Hi there,
when the light comes on, a fault code will be set in the ECU memory and it can be retrieved and analysed, you do not have to have the light on to extract or check for codes, this is just a visual warning that a code has been set.
Mark (mhpautos)
Mar 9, 2008 at 9:18 PM
