1996 Hyundai Excel Linkage from shift lever to transmission
1996 HYUNDAI EXCEL
92,000 MILES • 4 CYL • FWD • MANUAL
NICKPR
  • 6 POSTS
I was suddenly unable to shift gears.
There appears to be a disconnect between shift lever and gearbox. I can get the car into gear by moving the mechanism at the transmission manually, the transmission end of the connecting cables (shift lever to transmission) are connected ok. Once in gear, by pushing the gearstick forward, it will move the car out of gear, but nothing after that. A diagram of how it all connects at the gearshift lever end would be a help before I try to pull it all apart. Any brief suggestions on checking out the mechanism would also be helpful.
Jul 24, 2010 at 5:49 PM
MERLIN2021
  • 17,250 POSTS
Choices for Hyundai in 96' were, Accent, Elantra and Sonata, Which one are you driving?
Jul 25, 2010 at 2:43 AM
NICKPR
  • 6 POSTS
I live in Australia and the Excel was still available here in 96. Its the same car as the '94 and '95
very similar to the Elantra which replaced it.
Jul 25, 2010 at 12:26 PM
MERLIN2021
  • 17,250 POSTS
I will send what I have, but it's not too specific about the shift levers, Check the allen lock screw on the side of it, it may have loosened up.
Jul 26, 2010 at 7:47 AM
NICKPR
  • 6 POSTS
thanks for that, useful info in any case. It turned out to be a broken bowden cable between the lever mechanism and the gearbox. Had to replace the whole set as they come as an assembly. Fiddly job getthing the cables in and out but got there in the end. Shifting a lot more precise now with very little play in the linkages. cheers, Thankfully it was nothing worse.
Jul 26, 2010 at 6:37 PM
MERLIN2021
  • 17,250 POSTS
OK Good work Nick
Jul 26, 2010 at 7:20 PM
