2002 Hyundai Elantra P0441 code
EB123
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 110,000 MILES
I got a p0441 code incorrect purge flow and I changed the gas gas vapor canister vent valve, I m guessing that the vapor canister itself, I tested the purge valve in the front and it's still getting current. But after driving it for a while the damn thing still pops up, I was wondering if anybody knew what else could be causeing that code.
ps- I put a resistor on the IAT sensor soo it shoots extra fuel, and theres a hissing noise coming from the gas tank.
thanks,
Johnyboy1223455
Thursday, August 14th, 2008 AT 3:33 PM
JAYLOW
  • 9 POSTS
Your evap canister lives rt behind your fuel tank w/3 lines running from it. You need to examine evap canister and the lines back there sounds like you have a leak in the unit itself or the line. Hopes this helps
Wednesday, August 27th, 2008 AT 5:41 PM
