The purge solenoid is in the emissions system to keep gas fumes from venting into the atmosphere. If you have a code for it, this does not necessarily mean that it is bad. The problem could be as simple as a vacuum leak. Check all of your vacuum hoses under the hood for leaks. Listen careful for any hissing noises coming from them.
You can check your local auto parts stores such as AutoZone or O'Reilly Auto Parts to see if they have the part for your vehicle.
SPONSORED LINKS
Tuesday, November 11th, 2008 AT 2:56 PM
