2001 Hyundai Elantra engine removal
11,000 MILES • 4 CYL • 2WD • AUTOMATIC
DGREEN4298
is it possible to remove the engine without removing the transmission or taking loose the sub frame of my 2001 hyundai elantra? how would i get the torque converter unbolted, remove the oil pan?
Jan 22, 2009 at 12:15 PM
  • 110,248 POSTS
You should be able to unbolt the trans and the pull the engine through the top. Remove the hood so you have as much room as possible. The torque conver will come out with the engine. Once it is out, then unbolt the converter and remove the oil pan.
Mar 24, 2009 at 10:41 AM
DGREEN4298
it is not possible, the engine is too close to the frame, beside i found out that you can unbolt the torque convertor through the starter hole. but thanks anyway
Mar 24, 2009 at 3:19 PM
  • 110,248 POSTS
Hi:
I figured once it was loose, you would be able to move it around to gain clearance. As far as the converter, yes that is possible, since they don't have the inspection plate below.
Good luck, and if you have other questions, let us know.
Mar 25, 2009 at 5:04 AM
