2000 Hyundai Elantra Belts
VALBOWSKI
Noises problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic
I am aware that I need to change the belts on my car, but I am unsure as to which belt is which.
There are two that I can see when you pop the hood. The one nearest the engne block is???
And then what is the other one callled?
Just need to know for when I calll around for pricing to replace them.
Sep 28, 2009 at 11:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle should have 2 belts. One being the drive poly v-belt that goes around the pumps and pulleys (power steering pump, water pump, etc...). The other is the timing belt that goes around the camshaft & crank (belt closest to engine) .
Sep 28, 2009 at 2:59 PM
