i have a 2000 hyundai elantra that doesnt want to pass 40 mph and takes a while to pick up speed.
Saturday, September 26th, 2009 AT 12:11 AM
MECHANIC
Have you checked the catylatic converter to see if it is plugged? Also, has the check engine light come on?
SPONSORED LINKS
Monday, September 28th, 2009 AT 8:24 AM
GREASEMONKEY34
MEMBER
Yes it has a new catalytic converter and yes the check engine light is on. I took it to auto zone an put it on a diagnostic tester and the only thing that came up on it was a couple of sensors. I forgot what codes there where.
Monday, September 28th, 2009 AT 9:30 AM
MECHANIC
If the codes identified sensors, then chances are that is the problem. Have you tried replacing them?
