hyundai atos Air Control Vavle Problem
105,000 MILES • 1.0L • 3 CYL • MANUAL
NAEEMWAJID
Dear Sir, when i would drive my car then some time race was going little bit higher, I thought it would be Air Control Vavle problem, Can you help me who i can solve that problem.
Regards Naeem
Sep 17, 2014 at 7:11 AM
  • 110,251 POSTS
How high are the RPM going? Have you checked for vacuum leaks?
Sep 17, 2014 at 1:17 PM
NAEEMWAJID
How i can check that sir?
Sep 17, 2014 at 6:04 PM
  • 110,251 POSTS
There are vacuum hoses that are on the engine and around it. Check to see if any are disconnected or in poor condition. Some people use carb cleaner and spray it on the vacuum hoses and around the intake. If there is a leak, the engine RPM's will increase. However, you must be careful when doing this because the carb cleaner is flammable.
Sep 17, 2014 at 10:08 PM
