1999 Hyundai Atos air con not working
50,000 MILES • 4 CYL • 2WD • MANUAL
ALPAR1
hi
air con regassed last year, worked ok, now not working at all - switch works, fan blows, A/C light comes on, but no change to engine revs at all, no 'draw' on power/revs; is it another regas or a leak/compressor gone? And if it a leak can it be done by the handy home mechanic or is it a garage job?
thanks
car is in UK
May 20, 2010 at 11:20 PM
  • 31,937 POSTS
Hi there,
I feel that you have a leak in the system, what needs to be done first is to get a small charge of refrigerant inn the system with a leak detector dye, this will stain where the leak is, this is the industry standard for A/C leak detection, this really should be done by an A/C tech.
mark (mhpautos)
May 20, 2010 at 11:27 PM
ALPAR1
thanks for that - I think when it was regassed last year it contained the dye so they should be able to find it - going to ring round and get some quotes
thanks again for your help
May 20, 2010 at 11:47 PM
  • 31,937 POSTS
OK. good idea, thank you for using 2carpros, feel free to re post if you still have any problems.
Mark (mhpautos)
May 21, 2010 at 12:08 AM
