2003 Hyundai Accent Problems with filling the fuel tank
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
JPFINLEY1
Recently, my Accent will not allow me to fill the tank without backing up the fuel and cutting off the pressure sensor in the stations gas pump. I have to dribble the gas in. I looked under the car and found a rubber hose going to what I assume is an evaporative canister. When I pinched the hose it felt "crunchy". Is there anything I can do, or do I have to take it to a dealer?
Jul 13, 2008 at 11:58 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9bbdcaaf3c="jpfinley1"]Engine Performance problem
2003 Hyundai Accent 4 cyl Two Wheel Drive Automatic 106000 miles
Recently, my Accent will not allow me to fill the tank without backing up the fuel and cutting off the pressure sensor in the stations gas pump. I have to dribble the gas in. I looked under the car and found a rubber hose going to what I assume is an evaporative canister. When I pinched the hose it felt "crunchy". Is there anything I can do, or do I have to take it to a dealer?[/quote:9bbdcaaf3c]
Sounds like the vent hose is clogged. Remove that hose and either clean it out or just replace it and see what happens.
Jul 14, 2008 at 12:12 AM
