2003 Hyundai Accent
2003 HYUNDAI ACCENT
11,000 MILES • 4 CYL • 2WD • AUTOMATIC
PICKLEMITCHELL
my car hesitates intermittently when accelerating. when my mechanic test drove the car, three times, it did not cause a problem. what can it be? it actually feels like you are hitting the brakes when accelerating. it jerks like that. does not do it all the time. same days it seems worse others it does not do it all. Tried different gasolines, had a tune up recently.
I will try to make a donation if you answer my question
May 12, 2010 at 1:25 AM
  • 110,244 POSTS
Usually, a hesitation is caused by a simple vacuum leak, partially cloged catalytic converter, or a weak fuel pump.
Has the check engine light come on? Have you checked for any of the things I mentioned?
May 20, 2010 at 4:02 PM
