2002 Hyundai Accent strut mounts and struts
2002 HYUNDAI ACCENT
82,000 MILES • 4 CYL • 2WD • MANUAL
ESTRICKER33
I was told when I got an oil change that my mount on my front right wheel is bad. I looked at it myself and it is indeed bad. Should I get both of sides done? What about the strut versus the mount? What determines whether I should get a new strut as well? I never know when to trust these people.
Apr 10, 2009 at 6:59 AM
BLACKOP555
  • 10,386 POSTS
to check the struts you should check for leakage. if you see leakage on the struts they need to be replaced. along with cracks on the coils of teh spring. or if one side sits higher or lower then the other.
Apr 11, 2009 at 9:34 AM
