2002 Hyundai Accent Check engine light
AMAZIN315
  • 2002 HYUNDAI ACCENT
  • 6 CYL
  • FWD
  • 138,000 MILES
Is there a way to reset the computer memory myself?
Tuesday, June 24th, 2008 AT 2:23 PM
KHLOW2008
  • 41,814 POSTS
Hi amazin315,
For most vehicles the memory would reset itself if no problem occurs after a preset number of times starting the engine, Normally 20 to 40 times depending on makes.
I am not familiar with your model but you can try removing the battery terminal for a few seconds. Pump the brake pedal a few times and reconnect the battery terminal.
Wednesday, June 25th, 2008 AT 10:14 AM
