Yes I think they are related.
There is a check valve on the top of the engine that releaves the fuel pressure of the vapors in the tank when your filling it, *this was put into effects for environmental isssues*. This gas vapors go to the Carbon canister under the hood via vaccum lines. Then when the car is started these vapors are burned off. If the valve is bad or the vaccum lines going to the carbon canister are blocked or cut it will not function properly.
If those are all good replace the carbon canister.
SPONSORED LINKS
Sunday, December 23rd, 2007 AT 8:05 AM
