2001 Hyundai Accent Spark plugs or shoddy mechanic work?
CJMAS
Shakes or Wobbles problem
2001 Hyundai Accent 4 cyl Automatic 100000 miles
I have a 2001 Hyundai. The mileage is a guess. I recently had to have my thermostat replaced. The very next day, I noticed water leaking. The following morning, as I pulled out of my parking space, my engine was shaking, a bad smell emitted, and the 'check-engine' light came on.
I immediately pulled over.
I took it back to the same mechanics, and they said the problem with the 'check-engine' light was a misfire, and that I need to replace my spark plugs.
Could a spark plug problem manifest so quickly? Is it suspicious that it happened so immediately after the thermostat was replaced? I want to trust these guys, but I don't know enough about cars to know if the sudden problem is natural.
Thanks,
Jul 30, 2010 at 10:24 AM
  • 31,937 POSTS
Hi there,
This can happen, it just may be a case of bad timing, there is nothing in the job he did first up that can interfere with the functions of the plugs, now if it is a plug problem so be it, i would like to know what the code was, but i feel that you shoud trust his judjment, but if thing do not workk out thern start asking questions.
mark (mhpautos)
Jul 30, 2010 at 11:16 AM
