GREEN MIL LAMP
RUNNU10
  • 2000 HYUNDAI ACCENT
Electrical problem 4 cyl Two Wheel Drive Manual
HI
IN MY HYUNDAI ACCENT A GREEN MIL LAMP (L/B ) APPEAR,
COULD YOU PLEASE EXPLAIN TO ME WHAT DOES IT MEAN
Hi
about my check eninge light its not on just the green L/B LIGHT
THANX
HUSAM
Monday, December 28th, 2009 AT 4:18 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,302 POSTS
The green oval with L/B indicates lean / burn. It indicates that your air to fuel mixture is not correct.
This is probably due to an engine misfire, I would start by changing the spark plugs, here is a couple of guides to help you get the problem fixed.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
https://www.2carpros.com/articles/check-engine-light-clear-codes
Cheers, Ken
Tuesday, April 25th, 2017 AT 11:50 AM
