2000 Hyundai Accent
TALLER CASCANTE
  • 2000 HYUNDAI ACCENT
2000 Hyundai Accent
I need to know, what about the code 1123.
Monday, October 25th, 2010 AT 11:30 AM
KHLOW2008
  • 41,814 POSTS
Hi Taller Cascante,
P1123 = Short term fuel trim additive air, system too rich.
NOTE:
For air/fuel ratio to be within limits, all sensors, components and systems associated with air/fuel control system must function within normal parameters. The air/fuel control system includes several sensors and the following components and systems:
"Â Intake air system.
"Â Exhaust system.
"Â EVAP control system, including purge control solenoid valve.
"Â Fuel Injectors.
"Â Fuel pump and fuel pressure regulator.
Failure Conditions (Short-Term Fuel Trim)
ECM will set DTC P1123 and illuminate MIL if short-term fuel trim value goes 10-15 percent rich, or if short-term fuel trim additive value is less than 0.4 mS, during 2 drive cycles. ECM will set DTC P1124 and illuminate MIL if short-term fuel trim value goes 10-15 percent lean for 30 seconds during 2 drive cycles. DTC P1123 or P1124 will be set when the following conditions are met:
"Â ECM is in closed loop operation.
"Â Engine speed is less than 1000 RPM.
" Engine coolant temperature is more than 158 °F (70 °C).
"Â EVAP canister purge system is not operating.
"Â Mass airflow is less than 7.5 grams per second (DTC P1123) or 5.5 grams per second (DTC P1124).
Thursday, November 4th, 2010 AT 8:52 AM
Related General Content
