1999 Hyundai Accent fuel tank fill slow
8,900 MILES • 4 CYL • FWD • MANUAL
SUZONKA
  • 12 POSTS
I have a filling fuel back up problem ,I checked under the wheel well where the hoses are and they dont look crushed? some one said try to poke a coat hanger down the filler tube and there's a turn over flap that may be jammed ,what do you think?
Mar 15, 2009 at 4:06 AM
  • 110,248 POSTS
Hi:
There is a safety device that is designed to prevent fuel from leaking in the event of a roll over. It could be a flap, or a check ball. You could try to carefully do what you friend has suggested to see if there is any restriction.
Mar 24, 2009 at 1:15 AM
SUZONKA
  • 12 POSTS
[quote:1f4734993f="Jacobandnickolas"]Hi:
There is a safety device that is designed to prevent fuel from leaking in the event of a roll over. It could be a flap, or a check ball. You could try to carefully do what you friend has suggested to see if there is any restriction.[/quote:1f4734993f]
tHANKS, i THINK iLL TRY IT WITH A PIECE OF STRAIGHT SMALL OD PIANO WIRE
Mar 24, 2009 at 3:56 AM
