HVAC problem, no heated air flow?
145,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
RANDYROCKHOLT
The blend air door appears to be broken. I removed the actuator, which works and is not damaged, but the part that it connects to is broken loose inside the blend door case. I need complete instructions and diagrams on how to install a new blend door, along with part ID numbers and where to get these parts.
Nov 23, 2024 at 5:43 AM
STEVE W.
  • 15,411 POSTS
The OE method for this repair is basically to remove the dash, discharge the AC and drain the coolant, remove the HVAC case and split it so you can access the door. Then replace the heater core and AC core (unless they are in very good condition) and reverse the process to put it back together the book time is over 12 hours. Or you can do a shorter method that involves far less work to do. It is cutting the side of the HVAC case open, replacing the door and then you glue the cut section back in. There is an excellent write up using an equinox (same HVAC case) at:
https://www.terrainforum.net/threads/2010-2016-hvac-blend-door-replacement-without-removing-the-dashboard-hack.28713/
With a pdf download that has images of the process. The cuts can be done far neater if you have a hot knife or one of the vibrating tools.
I use the same process myself as it cuts over 10 hours off the book time and you can still drive the vehicle if needed because the interior is still together.
Nov 24, 2024 at 1:04 AM
