Humming sound but stops once it is in neutral?
14,500 MILES • 2.0L • 4 CYL • 4WD
DVGENTLES
Car hums when in drive even if the car is stationary but stops once it is in neutral.
Sep 23, 2024 at 10:31 PM
  • 55,588 POSTS
So, this can be the engine or transmission mounts, it could be part of the exhaust system is contacting the frame. I would put the car up on jack stands or a hoist and then have someone in the car as they produce the noise follow it to its origin. It could be the transmission itself. Lift the hood and use a flashlight to help find what is making the noise. We need more information to be able to help you. Please go over this guide:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 24, 2024 at 8:32 AM
