I have a H2 Hummer year 2003 approximately 98,000 miles and the windsheild wipers are coming on with out being turned on . They will not go off.
Jan 16, 2007 at 1:58 AM
Check the manual wiper switch and the windshield wiper control board. Faulty solder joints on the board connector can make the module think the wipers are mid-sweep and keep the motor running. Re-solder the visible connections or replace the board, and ask a dealer about a related recall.
A 2003 Hummer H2 owner reported that the manually switched windshield wipers turn on by themselves and will not shut off. One reply suggested a bad switch. Another explained that a faulty GM wiper control board, often from bad solder joints, can keep commanding the motor to park the wipers, and recommended re-soldering or replacing the board and checking for a dealer recall.
