HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hummer
Other
Drivetrain
Drive Shaft
Replace/Remove
2008 Other Hummer Models
SHAWNPAT
MEMBER
2008 HUMMER
how do you properly install a drive shaft?
Thursday, January 15th, 2009 AT 12:06 PM
DR LOOT
MECHANIC
Your question was "how do you properly install a drive shaft?" You put it back in the same way you took it out, just make sure you lube the U-joints when you're done.
Thursday, February 19th, 2009 AT 9:36 PM
Please
login
or
register
to post a reply.
Related Drive Shaft Replace/Remove Content
GUIDE
Driveshaft Removal
A driveshaft is responsible for transferring engine power from the transmission to the differential and onto the drive wheels. A driveshaft can be one or two pieces with a...
Transmission Filter and Fluid Replacement
Transmission Mount Replacement - RWD Cars
Transmission Service - Automatic
