Howling grinding noise
170,806 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TWIN TWIN
When driving the truck, it makes a howling grinding type noise from the front. Had hub bearings replaced and still have noise I think it’s coming from front differential.
May 1, 2022 at 3:33 AM
Clearly this does point to a bearing issue as you are suspecting. The only thing we have to be careful about is a noise that is translating from another source to make it sound like it is coming from the front.
Here are a couple guides that may help others with this as it sounds like you are narrowing down your issue:
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/car-howling-noise
What I would do for this specific issue at this point is lift the vehicle on jack stands and spin the wheels so that you can lay under it and pinpoint where the noise is coming from.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Based on experience, I am going to suspect this is a pinion bearing in the front differential.
So that means you should be able to service the front diff and find metal in the fluid.
https://www.2carpros.com/articles/differential-service
Please run through this info and let me know what you find.
Thanks
May 2, 2022 at 5:34 AM
  • 55,785 POSTS
What ever happened here?
May 18, 2025 at 11:33 AM
