How to handle old gasoline prior to starting car
1991 TOYOTA CAMRY
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOB OXENREITER
The car has not been driven in about eight or nine years. The car was running perfectly when i quit using it. I wanted to keep the car until i retired so i could tow behind an RV. I started the car on a regular basis for four or five years and then it tailed off. What do i need to do with the fuel lines and gas tank, if anything? I have not tried to start the engine.
Apr 8, 2018 at 8:31 AM
  • CERTIFIED EXPERT
Good morning.
You will need to drain the tank of all fuel. I would have the tank flushed out of all debris as well. replace the fuel pump while you are there.
I would replace the fuel filter and flush out the lines as well.
as far as the old fuel, put it in containers and take them to a service station and have them dispose of the fuel.
Apr 8, 2018 at 9:11 AM
