ABS, traction control, and brake light on
2003 PONTIAC AZTEK
133,329 MILES • 6 CYL
MATTHEWM1981
How to turn off the trac off and anti brakes and brake light?
Jul 17, 2019 at 11:49 PM
Hi Matthew,
More than likely this is a speed sensor issue because they are the most common cause of the ABS, Traction control, and brake light being on.
However, you will have at least one code in the ABS module pointing us in the right direction. Without those codes we are just guessing.
When you retrieve the codes make sure it is a scan tool that can communicate with the ABS module. Some cannot and it leads you to think there are no codes. If these lights on are, then you have some codes.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Jul 18, 2019 at 4:57 AM
