How to change cluster bulb
198,000 MILES
DAVIDNARAYANAN
  • 7 POSTS
One of the gauge cluster bulbs is not working and I am planning to replace all bulbs as the car is 18 years old. Is there a diagram or procedure to replace cluster bulbs of 95 camry.
Thanks,
Narayanan
May 11, 2013 at 8:39 AM
  • 31,937 POSTS
Not really, the cluster comes out fairly easily, pull the combing trim just check for all screws, this is the tricky part, there are some clips that will probably fall out when you pull the trim so be careful, the dash unit is held in with 4 screws and when you remove you will have to unplug all the loom plugs into the dash, they are different sizes so you can't mess that up.
May 11, 2013 at 8:46 AM
