how to test the crankshaft and camshaft sensors with a multimeter
244,074 MILES • 2.4L • V6 • 2WD • AUTOMATIC
ROBERT HAYES2
  • 6 POSTS
how do you test the camshaft sensor and crankshaft with a multimeter?
Dec 10, 2016 at 3:53 AM
CARADIODOC
  • 34,414 POSTS
You cannot. Those sensors have circuitry inside. You cannot measure resistance through that. To test if those sensors are developing signals, you need a scanner to view live data. Each sensor will be listed with an indication telling if the signal is getting to the Engine Computer.
If you have an oscilloscope, you can use that to look at the signals on the two signal wires. As a former TV repairman, I have multiple oscilloscopes, but I have never tried to use one for this purpose. Letting the scanner talk to the Engine Computer is so fast and easy, I would never bother with an oscilloscope.
Dec 10, 2016 at 5:24 AM
JIMFARNSLEY
Cam sensors can be tested with a multi-meter.
Jul 17, 2017 at 4:58 AM
CARADIODOC
  • 34,414 POSTS
Really? Tell us how you do it.
Jul 17, 2017 at 4:23 PM
