This is common with the S series trucks. The way to fix it is to replace the entire fuel pump assembly, which costs more than $220.00 for a cheap aftermarket pump, which will likely only last a year or two. Personally, I would not bother with it.
Lowering the tank does not take long. First, depressurize the fuel line by taking out the fuel pump fuse or relay while the engine is idling. Then unhook the fuel line where it connects to the fuel filter (should be on the driver's side, under the truck, along the inside of the frame rail). There are two straps wrapped around the tank that are bolted on one end. You will have to look around the tank and unhook the various hoses, unhook the fuel line, and then undo those bolts.
If there is much gas in the tank (more than a quarter tank) I would suggest draining that fuel before putting the tank back up. The weight of it makes it a real challenge to put the tank up and put the straps in place, and bolt them up, all while laying on the ground under the truck.
I have heard of people taking the bed off instead, and leaving the tank bolted into place. Apparently it is easier to do that if you have a helper. Also, I have heard of people cutting a hole in the bed to create a service hole of sorts.
Hope this information helps. Please let us know if you need anything else.
Oct 5, 2017 at 1:03 PM
