How do you gain access to radiator drain cock
17,000 MILES • 6 CYL
BILL89134
There is no visual of radiator drain cock. Where is it located and how to gain access?
Aug 7, 2017 at 10:36 AM
CARADIODOC
  • 34,403 POSTS
Pull the lower radiator hose instead. I haven't opened a petcock since the mid '90s when we had a rash of failures. They almost all use plastic radiator tanks with plastic petcocks with a rubber o-ring. Opening the petcock causes the plastic to crack where the o-ring pushes against it to seal, then you have a constant drip, about once every five seconds. The fix is to replace the radiator. Safer to just pull the hose.
Aug 8, 2017 at 10:38 PM
