Hose from top of engine to air filter cracked and leaking
1995 JEEP WANGLER YJ
156,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
MONTOYAJOSH1996
The hose going from the top of the engine to the air filter, has cracked and is leaking oil at the side that goes into the engine. I attempted to repair it, just until I buy a new tube, but now my oil pressure is going almost to 80.
May 18, 2014 at 6:18 AM
HMAC300
  • 48,601 POSTS
I fyou blocked it off unblock it and just let it go towards the air or put a temporary hose on it. it doesn't have anything to do with oil pressure. it could be a bad oil filter if you recently changed it. or the gauge or sending unit may have gone bad. check oil pressure with a manual gauge.
May 18, 2014 at 8:33 AM
