Horn not working
2009 CHRYSLER TOWN AND COUNTRY
160,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
JMANN
  • 21 POSTS
I bought this van about a year ago and it came with a sticker already. Now that I need to get it inspected the horn does not work on the steering wheel along with the buttons on the steering wheel for the information center, but the horn works when you push the lock button on the keypad. it is not a fuse or relay, it does not seem to have a relay in the fuse is good. could it be possible spring clock issue?
Jul 19, 2017 at 3:41 AM
CARADIODOC
  • 34,381 POSTS
If the other switches on the steering wheel also do not work, the clock spring is the best suspect. The "air bag" light should be on too. The diagnostic fault code would be related to "open squib" or "open initiator circuit".
Jul 19, 2017 at 12:19 PM
JMANN
  • 21 POSTS
I put a new clock spring in but it still does not work while I took it apart I noticed that the other buttons share the same wires as the horn if one of those switches are out could it make the horn not work?
Jul 28, 2017 at 3:30 AM
CARADIODOC
  • 34,381 POSTS
On older vehicles there was a wire going through the clock spring's ribbon cable for each switch, but there weren't very many switches. When they added a dozen switches for everything but an electric chicken plucker, it became impractical to have that many wires. Instead, each switch develops a variable voltage, and all of those are sent on a single wire. One of the computers interprets each voltage as the request signal for what that switch is for. To answer your question, yes, you can have a single defective switch while all the others work fine.
I haven't worked on a horn problem yet on a vehicle as new as yours, but Chrysler did have a big problem on older trucks starting in the late '90s. The horn switches were built into the steering wheel air bag's cover, and caused a lot of dead horns. The switches worked if you pressed them really hard. The fix was to replace the air bag assembly.
There also was a problem on some trucks where the bolt holding the horns broke, then the horns would fall off, and all you'd be left with was a pair of wires hanging down. Another common problem was one of the two horns would short, and that would cause the fuse to blow. If the vehicle was still under warranty, we had to determine which one needed to be replaced, and use one supplied by Chrysler. For vehicles out of warranty, it was less expensive for the customer if we used a universal replacement horn.
Given the variety of things that can cause a dead horn, the best approach is to use a scanner to access the Body Computer, and / or the Integrated Power Module, (under-hood fuse box)), to command it to activate the horn. The scanner will also list the horn switch as "off" or "on". If you see it change when you press the switch, you know that part of the circuit is working.
Another clue is if the horn chirp works when you lock the doors with the remote, (if that option is turned on). If you hear that chirp, you know the horns and fuse are okay.
Jul 28, 2017 at 2:17 PM
