won't crank after a battery and radio swap?
96 MILES
MARIA SCOTT
Does the radio have anything to do with my car listed above LX won't crank after a battery and radio swap?
Jun 7, 2020 at 6:49 AM
I do not expect the radio to be the cause of this. The battery being replaced has been known to cause the theft system to go active and then the vehicle will not restart when the battery is hooked back up. When you turn the key to the on position does the theft light turn off or does it stay on or blink? This sounds like the starter is having problems or the battery needs to be load tested these guides can help us fix it.
and
Sep 30, 2020 at 5:48 AM
