1995 Honda Prelude Fans Run After Shutdown
Suggested Repair
Inspect the radiator closely for leaks, wet spots, or restricted flow, and purge air from the cooling system. Because coolant must occasionally be added, also investigate coolant loss from a slow head-gasket leak. The engine-cooling fan should run when the temperature sensor calls for it, not only after shutdown.
Conversation Summary
A 1995 Honda Prelude overheats at stops, then cools while moving, and a cooling fan runs for several minutes after shutdown. Coolant, the radiator, hoses, thermostat, and radiator cap were already addressed, and both fans operate. The expert said the post-shutdown fan indicates the engine is too hot and recommended checking for a radiator leak or blockage and possible coolant consumption from a head-gasket leak. The owner found no visible leaks, bled the system, and saw the fan run at a normal gauge reading, but had not yet confirmed a highway-test result.
