Does it crank
and if so timing belt would be 1st to check
if timing belt broke then expect bent valve and valve job ($$$$$)
if no crank
do you have any power as light radio and if not suspect and check alternator
charge battery and try to start and check charging system
good luck
SPONSORED LINKS
Saturday, December 13th, 2008 AT 11:08 PM
