1992 Honda Prelude Idle Surge
TOEKNEE
  • 1992 HONDA PRELUDE
Engine problem
1992 Honda Prelude 4 cyl Front Wheel Drive Automatic 250xxx miles
Hi, I'm just wondering why my car surges RPMs when I let off the gas. When I drive and then let off the gas to brake my RPMs go up and down about 2 times.
Saturday, December 29th, 2007 AT 2:46 PM
MERLIN2021
  • 17,250 POSTS
You have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! Or a stuck EGR valve.
Saturday, December 29th, 2007 AT 2:47 PM
TOEKNEE
Do I spray inside the lines or on the outside? What's gumout supposed to do?
Saturday, December 29th, 2007 AT 3:31 PM
MERLIN2021
  • 17,250 POSTS
You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Saturday, December 29th, 2007 AT 7:53 PM
TOEKNEE
Ok, I'll try that. Thank you!
Sunday, December 30th, 2007 AT 12:12 AM
