2005 Honda Pilot A/C Blows Warm Air
OURIONE
A/C blows only warm air, is there a way of repairing this issue without going to a shop? Thanks
Jun 20, 2007 at 2:54 AM
BRUCE HUNT
  • 3,754 POSTS
I would venture that he A/C is using 134 coolant. You can go to Walmart and pickup a kit with the gauges included for about $25. This has the refrigerant included and see what the guages indicate for the refrigerant level. That is an idea. BUT I look at the newness of the car and I wonder if you can tell when you turn on the A/C if the compressor kicks on or not. I might suggest looking for a fuse that could be blown.
Jun 20, 2007 at 6:04 AM
OURIONE
Thanks for the input, i wasn't aware that coolant was so readily available, is this the the material they call "Free on" ? and yes i will check to make sure the compressor kicks in.....But if its not...Any suggestions on that topic?
Thanks once again
O
Jun 20, 2007 at 7:18 AM
BRUCE HUNT
  • 3,754 POSTS
I wouldn't call it Freon but it does the same thing. After early 2000 something all vehicles use R134a refrigerant. I would bet your vehicle does as well. It should be listed or dsiplayed on the vehicle under the hood or on the compressor,etc in the engine compartment. On older cars you can remove the R21 and replace them with the 134.
If the compressor is not kicking in I would look for a fuse. Fuses can be found in the passenger compartment usually down by the drivers knee or foot area. They are also found under the hood usually on the passenger side of the engine compartment.
Jun 20, 2007 at 8:55 AM
OURIONE
[quote:f728d8af0d="Bruce Hunt"]I wouldn't call it Freon but it does the same thing. After early 2000 something all vehicles use R134a refrigerant. I would bet your vehicle does as well. It should be listed or dsiplayed on the vehicle under the hood or on the compressor,etc in the engine compartment. On older cars you can remove the R21 and replace them with the 134.
If the compressor is not kicking in I would look for a fuse. Fuses can be found in the passenger compartment usually down by the drivers knee or foot area. They are also found under the hood usually on the passenger side of the engine compartment.[/quote:f728d8af0d] :D
Jun 20, 2007 at 9:39 AM
Suggested Repair
Confirm the system uses R134a (label under the hood or on the compressor). With a gauge kit, check the refrigerant level. When the A/C is switched on, verify the compressor engages; if it does not, inspect the A/C fuses in the cabin fuse box near the driver's knee and in the under-hood fuse box, typically on the passenger side.
Conversation Summary
The owner of a 2005 Honda Pilot reported that the A/C blows only warm air and asked about a DIY repair. The expert said the system likely uses R134a rather than older Freon, and suggested a low-cost gauge kit to check refrigerant level. They also advised confirming whether the compressor engages and checking cabin and under-hood fuses if it does not.
