2003 Honda Pilot Malfuction Indicator Lamp
68,000 MILES • 6 CYL • FWD • AUTOMATIC
DLKESSEL
Despite the fact that my Pilot is an automatic, I still occasionally shift into neutral and glide down the hill near my house each morning on my daily commute. The Pilot has a steering column shifter, and one morning, I accidentally slipped past neutral into reverse. I immediately shifted out of reverse, and felt no disturbance in the engine/transmission/anything. However, a week later, the malfunction indicator lamp came on, which could mean any out of a million things. Did my mistake injure the car's transmission?
Nov 3, 2010 at 10:44 AM
CARADIODOC
  • 34,393 POSTS
Hi Dlkessel. Welcome to the forum. I did the same thing to my rear-wheel-drive car many years ago. Within days, it developed a pulsing vibration at highway speeds that would come and go about every three seconds. It took over five years to figure out the problem was a cracked nose on the torque converter allowing to to wobble off-center. It finally cracked and wore down so far it let transmission fluid leak out when the engine was off. I made it home 80 miles, replaced the torque converter and front bushing, and drove it another 90,000 miles with no more vibration.
I got lucky, and you did too if reverse still works. In reverse, a band is tightened around a drum that is rotating when going forward but normally not rotating when standing still. That drum is really tough but the band is easy to break. If it does, you won't have reverse.
The first thing to do is have the diagnostic fault codes read and recorded. There will be at least one in memory since the Check Engine light came on. It is doubtful the light is related to the transmission, especially if the transmission is still working fine.
For the record, unlike older carbureted cars, newer models cut the fuel injectors off during coasting to improve fuel mileage. High manifold vacuum is the signal for the Engine Computer to do this. The transmission is tugging on the engine, so to speak, to keep it rotating. The injectors are slowly turned back on as the engine approaches idle speed or you begin to accelerate. When you shift to neutral, fuel metering has to increase to keep the engine at idle speed, other wise it would stall. Even with an older car like mine, shifting to neutral saves almost no fuel because the throttle blade is closed. The thing to keep in mind is the engineers designed the car to be as fuel-efficient as possible, and they designed it to be that way under normal driving conditions. Shifting to neutral is not a normal condition.
caradiodoc
Nov 3, 2010 at 11:52 AM
DLKESSEL
This is how one learns...thank you for your quick response and helpful information. Reverse still works fine. I will take the car in on Monday to have the codes read. The only reason it concerned me momentarily was because the car has never had a problem, and for a light other than the classic "Check Engine" to come on really threw me off guard. Hopefully it'll be a quick fix. The car has been perfect so far.
Nov 3, 2010 at 12:04 PM
