Engine Vibration @ 40-45 mph
1940 HONDA PASSPORT
GMATT24
Hello, I own a 1995 Honda Passport (Isuzu Trooper) w/ 85,000 mi. I am expieriencing some pretty bad engine vibration at 40-45 mph to the point I must let off the gas to stop the vibration. If I gun the engine from a lower speed up past 50 mph the vibration is not nearly as bad as when I slowly accelerate up to speed. Any suggestions as to what's causing this? Thanks!
Sep 14, 2006 at 9:29 AM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
There are tests you can do for free to check on the motor mounts. Start with that.
Sep 26, 2006 at 7:27 AM
