1998 Honda Passport egr valve
1998 HONDA PASSPORT
97,500 MILES • 6 CYL • 4WD • AUTOMATIC
JCOUSINS2007
can a egr valve on a 1998 honda passport be cleaned
Sep 26, 2009 at 1:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you can try cleaning it first before replacing it. be sure to clean the passage to the EGR valve as well though. to clean the EGR valve , be sure to use carbon cleaner. Carbon cleaners can be purchased at auto stores. Just turn the valve upside down on a stable surface and fill it up with cleaner. Let it soak in the cleaner for at least 8 hours. Then, use a wire brush to remove any visible deposits left on the EGR valve. After soaking in the cleaner, any deposits should brush right off.
Jan 10, 2010 at 3:10 PM
