1994 Honda Passport 6 cyl Four Wheel Drive Manual
I've been having a continuing problem with this car, sometimes it will start and run just fine and sometimes it will not start at all. Fuel pump relay had a jumper wire ran from the fuse panel, came loose once, found that and then car ran great for a few weeks, now it's just hit or miss. It will start and run just fine sometimes and other times it won't fire at all, try it again in a few hours and it starts again. I've had the car in a shop, well that's what they call themselves anyway, what a rip off. They checked out the relay, said not the problem put on plugs, wires, fuel filter, fuel pump and thermostat $997.50
Any idea what this might be?
SPONSORED LINKS
Tuesday, January 19th, 2010 AT 3:19 PM
