Honda CD Player Shuts Off When Loud
HONDA
THEBADGUY1337
ok, i have a new kenwood cd player and i have it wired to my automatic door locks from the fuse box to my memory wire to keep it on which song i had it on....ok i dont know if that is the problem or if my battery is the reason my cd player keeps shutting off if i turn it up too loud. but as long as im on the road it doesnt turn off no matter how loud i turn it up unless i come to a stop....
can anyone help me with this...
Jun 6, 2006 at 1:52 PM
BRUCE HUNT
  • 3,754 POSTS
I have seen more problems with wiring of radios than I should. Try another location to wire the radio. The radio probably has its own fuse in line, so why not try connecting directly to the battery to see if it resolves your problem. If it does, find another spot to connect to.
Jun 12, 2006 at 3:47 AM
ANDSTEELE
I understand why you have wired the radio to your doors but please do the job properly!! Now the positive cable that stores radio presets etc usually goes through the ISO connection. Most cars have this. However if not, send that wire directly to the battery (with an inline fuse) Persides, won't the radio lose its memory as soon as you turn off the ignition the way you've done it?
Jul 6, 2006 at 4:20 AM
Suggested Repair
Do not power the radio memory wire from the door-lock circuit. Connect the constant/memory wire to the battery through an inline fuse, or to another proper constant-power source, and confirm the shutoff stops before choosing a permanent connection.
Conversation Summary
A Honda owner with a new Kenwood CD player wired the memory wire to the automatic door locks so presets would stay. The player shuts off when turned up loud, especially at a stop, but stays on while driving. Advice is to rewire constant power properly to the battery with an inline fuse, or another suitable constant source, rather than the door-lock circuit.
