2002 Honda CR-V Rotten Egg Smell
2002 HONDA
RBOLT2
Problem : I get a rotten egg smell when ever I drive up a long steep hill. I have plenty of power and extra excellation if needed. I doesn't matter what the weather conditions are it can be hot or cold dry or wet I get this consistent rotten egg smell. Is this normal or should I be concerned. Currently I have 116000 KMs but this is something that my CRV did pretty much from day one. I have taken this to the dealer and they said it's normal and to try a fuel additive???
Apr 30, 2006 at 1:44 PM
LOSONE
  • 1,616 POSTS
The smell is a catalytic converter smell. Either is is going bad or you have a rich engine condition.
May 1, 2006 at 6:40 AM
BRUCE HUNT
  • 3,754 POSTS
Another item that gets the rotten egg smell is the battery if it is getting an overcharge.
May 1, 2006 at 3:01 PM
Suggested Repair
Have the catalytic converter and fuel mixture checked for a failing converter or rich-running condition. Also test the charging system, since battery overcharge can cause a rotten-egg smell.
Conversation Summary
The owner of a 2002 Honda CR-V reports a consistent rotten-egg smell when climbing long steep hills, present since new and unrelated to weather, with normal power at about 116,000 km. A dealer called it normal and suggested a fuel additive. Experts said the smell can come from a catalytic converter that is failing or from a rich engine condition, and that battery overcharge can cause the same odor.
