2002 Honda Odyssey Revving in Park
MRS G
2002 honda odyssey, 90,000 miles, engine: water cooled 4 stroke SOHC VTEC 6cylinder gasoline ingine.
was driving with AC on, stopped and put van in park, it immediately began revving and then idling normally, back and forth as though i was stepping on the gas for about 3 seconds and then off for 3 seconds. i put it back in drive and drove a few feet, put it back in park and it did the same thing. then i drove about 1 minute and then put it in park a 3rd time and it idled like normal (no revving). i haven't started it since. what does that sound like?? THANK YOU!!!!
Jun 16, 2007 at 1:09 PM
BRUCE HUNT
  • 3,754 POSTS
I would venture that the car will idle normal when there is no A/C on. Try that. You are having some sort of vacuum leak, at least I believe that to be true and at least as a starting point. Look at vacuum hoses on the vehicle and listen for any sound as from a leaking hose. With the A/C on the car needs to adjust the idle speed to compensate for the extra pull of the compressor. It is not getting a clear picture of what is needed for fuel air mixture to run and is overcompensating.
Jun 17, 2007 at 1:47 PM
Suggested Repair
Test idle with the A/C off. Inspect vacuum hoses for leaks and listen for a hissing leak, since the idle control may be overcompensating for A/C compressor load.
Conversation Summary
A 2002 Honda Odyssey with about 90,000 miles surged between high and normal idle in park with the A/C on, then later idled normally. The expert suggested checking whether it idles normally with the A/C off and inspecting vacuum hoses for a leak that could confuse idle and fuel-air compensation.
