1992 Honda Odyssey dashboard lights
RENAE SWEENEY
Brakes problem
1992 Honda Odyssey 90,000 miles
I got stuck in sand. After I got out of it the TCS andABS lights remained lit on the dashboard.I did spin allot trying to get out. I was pulled out from behind. Is it safe to drive. I sounds normal.
Nov 28, 2008 at 11:04 PM
KHLOW2008
  • 41,812 POSTS
Hi renae,
It is ok to drive. The ABS and TCS has been trippped and you need to reset the ABS indicator light. At the underhood ABS fusebox remove the fuses for 10 seconds and retest.
Nov 29, 2008 at 9:35 PM
