2007 Honda Fit water tapping noise from under the hood
2007 HONDA FIT
70,000 MILES • 4 CYL • FWD • MANUAL
YMARTIN
I just bought this 2007 Honda Fit sports manual transmission. the next day I ran into a puddle of water due to heavy rain. since then, as I turn on the engine or when I slow down to stop the car, it makes water going up and down, side to side just like a water going through narrow passage. I can't see any visible water under the hood, or inside the car. Where does this noise come from? The car runs fine with no problem with any electric function.
Oct 4, 2010 at 11:03 AM
  • 31,937 POSTS
Have the A/C drain tube checked for a blockage, also if there is air trapped in the heater, this can make such a noise, start here.
Mark (mhpautos)
Oct 4, 2010 at 10:23 PM
HONDA TECH 1818
  • 536 POSTS
Probably there is air trapped in the heater core. Try bleeding the air from the cooling system.
Nov 7, 2010 at 2:27 PM
